No Xbox Surround Sound
TheGeek
1,090
I just got a 5.1 home theature system (i cant spell) and and HDTV. When I hook my Xbox up to my tv with my HDTV AV pack, and hook the red and white audio cables into my sound systems audio in port, i can only hear sound out of my front 2 speakers and the subwoofer. How come? the HDTV pack should be able to output surround sound. When i watch DVDs however, i get the full system working. Help would be appreciated
thanks
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
You need to use a digital cable to connect from the av pack (the black connector with the door) to your stereo. The white/red cables are just left/right channels AFAIK.
Bill
TheGeek
1,090
Bill
fvck. my DVD player/ sound reciever doesnt have digital audio in. is there an adapter i can get?
TerryMathews
Bill
No.
Edit: Yes, the adapter is available. It's called a Dolby Digital 5.1 home theater receiver. Many companies make this 'adapter'. :)
Slick5150
8,760
No digital in means no surround sound from the Xbox. Might want to invest in a cheap surround sound receiver. I've seen some deals recently on a pretty good Sherwood 5.1 receiver for like $80ish.
Zero Plasma
Banned
Jun 14, 2004
871
I think your just missing it.On the back of your surround sound there should be a black(or other color)little plug you pull that out and there is a cable called optical(go to radio shack or best buy)that goes from that hole to the same type of plug on you xbox hd thing.The cable a little costly 20-30 bucks I think just to let you know.But I highly doubt that you ss doesn't have this plug.
TheGeek
1,090
nope its not there. I think im just gonna buy a new reciever. Thnaks
EDIT: any suggestions on a home theater reciever and progressive scan dvd player with optical out?
Slick5150
8,760
You could just use the Xbox as the DVD player
Edit: Nevermind, I just noticed you wanted progressive scan (which the Xbox can do, but only if it's modded)
Jonesdaniel11
TheGeek, i am in the same situation as you. Did you find a good adapter in the end, because i am searching for one too, and am having trouble (or could anyone advise one ?)
