thestrangebrew1
I'm working on a Compaq Presario SR1913WM and at first I was getting static horizontal lines going across the monitor, and now it's not even getting a signal to the monitor. The monitor just cycles through signals (analog/digital) then says to check signal cable. I know the cable(s) work because I took them off my monitor to test.
On this Compaq pc I've tried the following:
Different monitor to rule out a faulty monitor.
Different cable
2 different video cards (7800 I had laying around and a Radeon 6450 I had in my htpc).
The PC itself only has onboard video with VGA hookups. With the gpu(s) installed, I tried both VGA and DVI. Neither was able to push a signal through to the monitor. I'm at a loss. I was thinking maybe the mobo might be dying out or perhaps I should try a different psu, but I don't really want to go that route except for a last option as I'll have to pull a psu out of my other htpc. All suggestions are welcome.
Different cable
