Originally posted by: Howard
Cast iron is just as heavy.
Well, I'd say cast iron is pretty durable...
Originally posted by: Transition
The blocks may be aluminum, but the sleeves are always some form of steel.
That does not make sense. He says the liners are always some kind of steel, and you agree and say that doesn't work?Originally posted by: yellowfiero
absolutely, you don't want to wear steel on aluminum!
No, he's saying that it does work. The sleeves go between the steel and aluminum parts, with the sleeve fixed against the aluminum. This way the moving steel part wears against the non-moving steel liner, and not against the aluminum part. Steel wearing against aluminum would wear the aluminum out quickly.Originally posted by: Howard
I thought that Nikasil was Nickle, Aluminum, and Silicon?Nikasil (nickel silicon carbide)
The Nikasil coating used in our cylinders is a nickel and silicon carbide matrix coating about 0.07mm (.0025-.003") thick. The nickel matrix is very hard, but it is comparatively ductile, whereas chrome is brittle. Dispersed through the nickel are particles of silicon carbide less than 4 microns in size. These extremely hard particles make up 4% of the coating and form a multitude of adhesion spots on which oil can collect. Beside providing a very long wearing surface for the piston and rings, the silicon carbide particles also contribute to longer engine life by ensuring good cylinder lubrication
Sorry, I didn't realize he was talking about steel pistons.
Fastar than yuo! Linflas!
You're right. Cool, I learned something.Originally posted by: Howard
Text
So, no forged steel blocks because there's no need for them?
It's a lot like nickel, only spelt wrong.Originally posted by: Howard
Anyway, I still have not figured out what nickle is.![]()
Better work on that past tense stuff, too.Originally posted by: Zenmervolt
ZV
Spelt. It's about halfway down the page and the second entry for "spelt". I'm just a sucker for those archaic words.Originally posted by: Howard
ZV![]()
