Well, I just got my 3rd 74gb raptor.
Tried to install it, with my other 2 raptors on my p5ad2-e mainboard. Plenty of connections (8 SATA connectors).
Went into the Intel controller config, deleted the current array.
Tried to create a new stripe with 3 drives and it wouldnt let me.
Found out, that the Intel ICH6 controller will not do 3 drive stripe.
SO, I connected the drives to the Silicon Image controller.
Created the array with no problem.
Installed Winxp and patched it up.
1st thing I installed was HD Tach.
Did some benching.
91MB/s which is about the same as when I had 2 Raptors connected in a stripe....
Shouldnt I be seeing alot better performance than this with the extra drive???
Or is the Silicon Image controller a piece of junk?
Ideas?
Did some benching.
Ideas?
