No sound in Vista/WMP11
Chism
28
Just rebuilt my computer and upgraded to Vista. Using Realtek HDA driver updated on 8/31/09. Everything checks out ok in Device Manager and the test sounds come through loud and clear using the Realtek Audio Manager program but, I get no sounds while performing normal Windows functions and can't play music using Windows Media Player. There's only one audio setting in the bios: choices are AUTO and Disabled - its set to AUTO. I raised all the output levels I can find to MAX using the speaker management wizard built into Windows. I removed the ATI HDMI Sound driver using device manager.
My board is a Gigabyte GA-EP43-UD3L.
I'm at a loss here. If anyone has any other suggestions I'd appreciate your input.
Thanks,
mpilchfamily
3,559
Make sure none of the sound sources are mute. Especially the Wave since thats where most audio comes from. All else failes go back to an older driver.
Chism
28
Just an update...there does appear to be sound but it is so soft I can only hear it in a silent room even though every control I have is set to max. Does anyone know of a secret volume control in Vista?
Comdrpopnfresh
1,202
maybe there is device + software volume controls? Like a realtek driver volume control, and then vista's?
