I have a box that I'm learning to use linux on. I have an ISA SoundBlaster 16 - very old, very well established. i have mandrake 7.1. I cannot get any sound. The "mixer" says that I need to
chmod a+rw /dev/mixer
which I did, to no avail. When I use the hardware configuration tool that mandrake supplies, and try to test the soundblaster 16(a) that it finds, I get the following error:
lib/modules/2.2.15-4mdksmp/misc/sb.o: init module: Device or resource busy
lib/modules/2.2.15-4mdksmp/misc/sb.o: insmod lib/modules/2.2.15-4mdksmp/misc/sb.o failed
lib/modules/2.2.15-4mdksmp/misc/sb.o: insmod sb failed
Any ideas what this means? I see the "smp" error in there - I am running dual p2-500s, and everything else works ...
help,
randal kohutek
help,
randal kohutek
