No sound in Counterstrike
StevenYoo
8,628
Hi,
Sound just stopped working during counterstrike. Sound is fine in the menus and sound is fine in the plain Half-Life game, but there's just no sound in CS.
It happened after I put in those buy-scripts.
any ideas?
hamburglar
2,431
Sometimes you lose sound in CS. Try restarting the game. If not, try without the buy-script or try another buy-script.
pumpkinhead76
205
I'm not sure if restarting the game is necessary. Generally, I lose sound when I get AIMed or something else pops up within windows and takes me out of CS. Sometimes when I click on the CS tab to go back to CS, I would have lost sound. The remedy that usually works for me is to hit ESC to go out to the menu, then push Resume Game. After I do this and it goes back into the actual game, my sound is usually working again. What did you use to do your buy scripts? A really good program that I like to use for that is CS Configurator Hope this helps.
