I have an Onkyo TS-SR502 receiver that's about a year old. I have a set of 5.1 Fluance speakers hooked up to it, and they have been working fine for the past year.
However, I am suddenly experiencing a problem where I get very low sound volume from the front right speaker. All the other channels work fine, but I can't hear anything from the front right.
I did the speaker level calibration from the set up menu, and If I set the front right to +12 and turn up the volume I can finally hear sound, but it is still very low. I know that the front right speaker itself works fine because I tried hooking that speaker up to the front left channel output on the reciever and the volume level was fine. I also tried resetting the receiver by holding down the video button while powering the unit up, and that did not work either.
If it makes any difference the sound sources I've tested this with are (1) Level Calibration from the receiver's setup menu, (2) Optical in from Digital Cable receiver, and (3) optical in from XBox while playing DVD's. Sound is fine in all three cases, except for front right speaker.
Is there something I can do to solve this, or is there a problem with the unit that would require service?
