NO S3TC problem at all on my Leadtek GTS by default!!!!!!!!!!
cool0221
589
Hi guys, it is usual or not. In my quake3 1.27g the skies are perfectly normal. I checked the registry the S3TC is set to 0, NOT 1. Plus I didn't do any command tweak under quake3...
oldfart
10,207
To enable texture compression in Q3 1.27, you have to set this in the q3config.cfg:
seta r_ext_compressed_textures "1"
Its not on by default. In previous versions it was seta r_ext_compress_textures "1" and it was on by default. BTW, try the 1.27h beta patch for a fps increase.
