No room for 2nd hard drive in case
glimmer
25
My case has two 3.5" bays intended for hard drives, but one of them is obstructed by my extremely long video card (3dfx 500 AGP) and want to install a second hdd. A friend suggested using double stick tape to mount it beneath the bays, but this doesn't sound like a good solution to me. Any suggestions of how I can mount it beneath the bays while keeping it secure and being able to remove it at a later date?
conlan
3,395
do you have a free 5.25 bay?? if so , stick the 2nd hard drive in a hard drive cooler and put it in there.
Mykex
380
Or just a set of 3.5 to 5.25 extention rails. They come with the Antec harddrive cooler fans at most CompUSA/Bestbuys type stores,most local shops will just have the rails about and will give you some cheap....If not free if you find the right place ;).
