- May 14, 2002
- 33
- 0
- 0
I'm putting together a new system but am not getting any power when I turn it on. The specs are listed below. The small green light is coming on when the power is connected, but nothing happens when I push the power switch on the case. The cpu and psu fans do not come on.
I tried a different psu in the system that is a 350 watt and the cpu fan would spin for a few seconds when the power cord is connected to the back of the psu. However, nothing happened when I tried to turn it on.
I took the board out of the case and tried it that way with no luck. I'm not getting any sounds at all from it when I try to turn it on.
I tried the psu in a AMD XP2400 machine and it was ok. Same for the memory. I used the xp machine to format the hard drive too.
If you have any suggestions, that would be great. I would appreciate it. Thanks.
The specs are:
Allied 400W PSU
Asus P4S800 Sis chipset
Intel P4 2.4 Hyper-Threading
Crucial PC3200 512 MB
Seagate 120 GB, 7200 RPM
The specs are:
Allied 400W PSU
