No POST when power is turned on
EvilManagedCare
Sorry if this is more appropriate for General Hardware, but I suspect it is an issue with the motherboard. Here is my setup:
DFI LANParty UT 250 (nForce 3 250 GB chipset)
2 GB PC3200 RAM
AMD 64 3700+
SB Audigy ZS
BFG Geforce 7800GS OC
Latest drivers
Possibly relevant info:
I installed new RAM to bring the PC to 2 GB recently. For whatever reason the DFI board at 2 GB will run the RAM at 333 instead of 400. However, you can change the settings to run at 400 in the BIOS. Other than that, there is no overclocking and I don't believe that can be considered overclocking. I did this about 4 days ago and there were no problems. Last night, however, I had a very slow boot up, then everything was fine. I rebooted at one point, and after the system turned off and powered back on, I got only a black screen, but the fans were still spinning. I never got the speaker beep and subsequent POST screen. I powered off and back on, the problem persisted. So, I am at a loss. There had not been any system instability prior to this incident.
Here is what I intend to try after work, and I would appreciate any feedback additional ideas for solutions:
1. Remove an occaisionally troublesome piece of hardware (a frontside USB hub connected to the leads in the motherboard) that seems to have slowed down the bootup sequence before
or
2. Remove one of the sticks of RAM
or
3. Switch out the video card (I don't think this is the problem, because wouldn't a problem with the video card give the errors signalled by speaker beeps?)
If none of that works I will reset the CMOS.
I really am at a loss, so any other direction will help. I don't suspect the power supply, which I believe is a 450W and there had been no previous instability.
Thanks for the help in advance.
So what happened? I'd appreciate the update, at least...
I believe I had this similar problem a few months back,
only it refused to fix itself.
Is that 2 sticks RAM or 4 ? Check into the RAM configuration as you might be stressing the mem controller by forcing it to run at 400. It looks like you should be ok, I think it's older than Venice chips that have the 333 issue but check to be sure.
