I recently put together a new system for a friend. I have put systems together before, and never had any issues. This time however, the system seems to give no output to the monitor. I have everything hooked up, and all the fans/LEDs power up with no problem. There is simply no indication on the monitor whatsoever that the system is powering on.
At first I thought it was a MOBO issue. So I RMAed the MOBO to Newegg. But a new board has not alleviated the problem. I have tried using different monitors and different video cards, so I believe I can rule both of those as a problem. Everything I've read says that I am now left with either a defective CPU or PSU.
So I intend to call Newegg tomorrow and see about getting one or both of them RMAed. However, I thought I would post here and see if I can get any suggestions on possible troubleshooting steps. My components are as follows:
Mobo - Intel BOXD975XBX2KR LGA 775 Intel 975X ATX Intel Motherboard - Retail
Vid Card - EVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 HDCP - Retail
PSU - CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100
CPU - Intel Core 2 Duo E6850 Conroe 3.0GHz 4M shared L2 Cache LGA 775 Processor
RAM - Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Monitor - SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD Monitor 300 cd/m2 700:1(DC 3000:1)
Is there any reason why these parts should not be playing well together? Is there anything else I can try to troubleshoot before sending those parts back? I have tried resetting the CMOS, but that did nothing either. Any suggestions would be greatly welcome. Thank you.
