Hi all,
I have an MSI K8T Neo2 FISR motherboard, and am using an GeForce 6800GT 256MB video card (AGP)
I have noticed an odd problem. My AGP aperture setting in the BIOS is currently set to 128megs. I was troubleshooting another problem with my system (essentially, every now and then when trying to display a video file in windows, or go to a folder which had videos that it generated thumbnails for, the resolution would get all screwy and the screen would be zoomed into a corner of the screen), and one person mentioned to make sure that the AGP aperture setting was the same as the card's video memory.
I went to the BIOS and changed it to 256 megs, and saved the BIOS, but after doing this, the system won't even POST (the diagnostic LED thing for the MSI K8T indicates it's an error in chipset initialization or something like that). The only way for me to fix it is to use the jumpers to reset the BIOS.
Does anyone have any ideas on what the problem might be? For the most part I haven't had any major problems running it with the AGP aperture settings set to 128megs, but it makes me worried that the system seems to choke when I try to set it to what the card has. Does it mean that it is only using 128 megs if I keep it at that setting, or something else?
-Zadillo
-Zadillo
