No OpenGL on 2nd head?
Armitage
Banned
I posted this on software first, but maybe this is the better place?
I've got a dual head setup on a Fedora Core 4 box. Left side runs on an AGP GeForce2, right side runs on a PCI TNT card.
I have an OpenGL application that runs fine on the left screen, and it always starts on the left screen. If I try to drag it over to the right screen, the menus & such still display, but the part of the window where the OpenGL animation should display is just a solid green.
I've recently installed the nVidia accelerated X drivers, which greatly helps the performance, but no change to the screen issue. The same thing occured on RH9 with video files, though I don't have any handy to try at the moment.
Any ideas? FWIW, I'm using the KDE desktop.
i know this doesnt really help you but in windows only fullscreen opengl is accelerated on 1 screen, i have no problem maximizing a windowd opengl app across both. so its possible, gotta be a driver issue.
