No monitor
RVN
1,154
RVN
I have a Dell P991 Trinitron monitor and am running XPSP2 Pro. It sometimes (often) boots up and no video. I've changed video cards and I've moved the monitor to another box and it's not the monitor, it's not the video card ...I'm pretty sure that it's the computer or part of it... a Dell PowerEdge SC400 with an unsupported AGP slot. Windows XP blue bars screen show up but then it turns off the monitor(s). First I have a question about the bios in that it has two parameters to work with ...AGP instead of onboard and number of MBytes. I know the card is 128 MB and have it set as such. It can also be switched to Auto. Then there is the S1 or S3 mode and auto start. I've tried all positions.
Somtimes it will boot up and "click" the monitor on and last. Sometimes it clicks on and then off during boot well after the mouse and keyboard become active. In the control panel there are options for controlling "power". I've checked the bios and power options against other computers and set them accordingly.
Is this a hardware issue? When I tried another video card it almost became reliable but after a couple of restarts it also failed. What more should I suspect is the culprit? Hardware? I have several images of the OS to change to and neither of them succeed for long.
Has this happened to anybody? ...that can help me. Is this suspect of a failing power supply?
Thanks!
pkme2
3,896
The Dell's have that PSU problem. When odd things start happening, its time to change PSUs.
How long have you had that unit?
RVN
1,154
It's not the power supply, I tried another one off a working computer. Even when I disconnect one of the two WD SATA 320GB hard drives and only run an optical drive and no floppy ...the monitor more often than not, doesn't power up.
Help!
