Only 1 IP per student at Purdue.Originally posted by: Evadman
Why are you using a router? They are made so that access is difficult. Get a 10/100 switch.
If you are worried about security, get a hardware or software firewall.
Ouch. Then use one of the computers as a hardware router. Like ICS. I use 602pro. You will be bale to see out, but seeing in is a different story unless the files are on the 1st system.Only 1 IP per student at Purdue.
