I built this pc a few years go and it's run flawless until now. I have a Dell 2005FPW that likes to go into power saver mode, always fixed by unplugging the monitor and resetting the PSU. a few months ago my 8800GTS 640mb failed, so I swapped in a spare 7600GT as temporary fix. A few days go my monitor went into power save mode and I was unable to fix it. I opened the pc and saw that the 7600 was slightly unseated and when I took it out saw some blown caps. I ordered a GTX460 and just installed it, everything spins up properly but I don't get a video signal on my monitor or on my Bravia. I'm wondering if the unseated 7600GT left me with a bad PCI - Ex slot? Any advice is very appreciated!
CPU: Intel Core 2 Duo E4300 Allendale 1.8GHz LGA 775 65W Dual-Core Processor
Mobo: Gigabyte GA-965P-DS3 (rev. 3.3)
GPU: EVGA GTX460 768MB
PSU: Enhance ENP-5150GH 500W
Memory: 4GB GSkill DDR2
OS: Windows Vista Home Premium 64-bit
*Update*
CPU fan is not spinning on startup. It jumps every few seconds but won't run, also there's no power to a keyboard I plugged into the I/O port. When I switch on the power supply the keyboard lights flash but when I power on the pc there are no lights. Both system fans are runnings well as the GPU fan.
*Update*
