Hey all...well, having a frustrating time here trying to figure out what the hell is wrong.
I just bought a DVD player (Shuttle 10X) and I'm using PowerDVD 2.55 along with a SBLive card. I have the SPDIF output of the DVD drive going into the SPDIF connector on the SBlive card. I can play audio cd's, and I do NOT have any other cables hooked up from the DVD to the sound card, (ie the analog audio connector), so I know that the SPDIF connection from DVD to SBlive card is working.
However, when I play a DVD (Matrix), I'm not getting any sound! I put PowerDVD audio setting to "Use SPDIF", and still no sound. Under "Info" I get:
Multispeakers Audio Device : Creative SBLive! (not in use)
S/PDIF Output Device : Creative SBLive! (not in use)
If I select "Use Wave Out", or "DirectSound" in PowerDVD, it workss fine!!!
My 1st question:
Since I only have the SPDIF cable hooked up between DVD and Sound Card, how is the audio information getting from the DVD to the Sound card? Is it being sent through the IDE cable? If it isn't being sent thru the IDE cable...is it then being sent through the SPDIF cable, but PowerDVD just doesn't state that (since it works under Wave Out and Direct Sound)?
My 2nd question:
How the hell can I get this to work!!!!!
I've tried other DVD's also...still doesn't work.
System Info:
MSI K7T Pro2-A(6330)
AMD T-bird 900 @1.1Ghz (not the problem)
SBLive with Updated Drivers and 4 speaker (analog) setup
Hercules Geforce2 Pro (updated drivers)
My 1st question:
My 2nd question:
System Info:
