- Overview of the problem
Computer does not boot, video card LEDs flicks on and off and beeps and power supply fan turns on and off every second.
- Full description of the problem and symptoms
In the previous boot, the monitor would not turn on, the cd drive continuously blinked, the wireless keyboard / mouse sensor would not stay on, but the fans were working fine and it seemed like it was booting up just fine except not appearing on the monitor. So I tried to force a reboot but it wouldn't allow me to do that so I had to turn the power supply off and when I turned it back on it would not boot. When I turned the power supply back on, the power and reset lights on the motherboard were lit just fine. However, when I press the power button, 3 of the Video Card LED lights blink on and off while beeping and the PSU fan spins on and off at the same intervals. The computer will not boot and stays in this state until I turn the power supply off. My best guess from what I looked up on the internet is that the LED lights signify power supply issues and that would make sense of all the other problems like the psu fan, monitor not turning on, and the at keyboard/mouse not working properly. However, I am also worried that this may be the video card or the motherboard. This may be unrelated, but a few months back my bios settings randomly reset itself.
- Did it work normally at one time, or has the problem always existed?
I built the computer 10-11 months ago and I have never had problems with it. It worked fine without any signs of trouble until this morning.
- My hardware
- Asus P5Q-E
- Intel E8400 (stock speed)
- VisionTek Radeon HD 4870
- 4 x 2 GB OCZ Technology PC2 8500 1066MHZ Reaper HPC edition OCZ2RPR10664GK
- Antec EarthWatts 500W EA-500D
I'm thinking my next step should be to purchase a power supply at Fryes and see if that fixes the problem but I don't know if there are any other steps I could try. Thank you for any help.
