So....wait for it.... Unplug the cable and plug it into the other one...
Its HDMI, not coax, it takes 2 seconds.
You're forgetting the space and power. So: unplug HDMI and power, pull off the AV rack and put it in closet, get other console from closet and put on AV, plug in HDMI and power.
Yes, that's easy to do if you use one for a week then switch to the other for another week, but I also use my PS3 for Netflix and Amazon.
The PS4 should eventually get all of the streaming apps, but then it adds the hassle of re-authorizing devices.
/firstworldproblems I know, but the point of owning these things is to have fun, not to be annoyed.
I only have so many HDMI ports on my receiver, and limited space on my AV rack.
I have a PS2 (component), PS3, 360, and HTPC connected now and have no room or spare ports.
If the PS4 and 720 both lack BC, I won't be in any rush to add them and remove an existing device.
Make sense now?
Why collect the old dusty games and worry about them if the hardware isn't worth keeping?I have 2 PS3's and 2 XBox's, and would prefer to just swap them out when the new consoles come out. I don't have any spare HDMI connections and would also prefer a nice clean setup (I don't want a stack of consoles sitting around). So for me, I definitely would like to see BC on the next gen consoles, but I might just be out of luck.![]()
Some of you are missing the point. It isn't that its technically possible to have 2 Playstations at the same time..
its that lots of people would see that as a waste. Particularly early on when there's not that many games for the PS4.
So the point is no BC means fewer sales at the outset, which means a smaller market, which means less incentive to develop games.
Btw, since I've been shopping for a PS3 for a couple of months I've been following the used PS3 market pretty closely. And just this past week there's been a spike in prices, mostly because the lowest priced ones are disappearing. But maybe its temporary.
This.Original hardware is better anyway. Even PS2 sucked at playing a lot of PS1 games correctly.
Just compare FF7 title screen side by side on PS2 vs PS1 and you'll see right away... And thats just a title screen.
