Hi guys, I just put together a new machine:
Gigabyte 8IEXPv2
Intel 1.8A
Turtle Beach Santa Cruz
ATI AIW 8500DV
Windows XP Professional
Sound works just fine on everything, but when I have the TV on, I do not get any sound whatsoever from the TV. The computer does play other sounds while the TV is on, so I do know that the AIW doesnt disable the sound card. Under the settings for the AIW TV card setup, it asks for how your sound card is hooked up to your video card. I tried all settings to see if any of them worked and I left it on the choice "Line In". I only chose that because that seemed to be the problem when peopel tried to capture their vids at ATI.com but no one seemed to have this problem just watching the videos.
I updated all the drivers already, any other ideas to what is wrong? It is not the coax cable, I did try that. Is there some sort of cable I need to buy to hook up the sound card to the video card, I defintely did not see that in the manual and neither card came with any extra audio types of cables.
Thanks
Spac3d
Gigabyte 8IEXPv2
Intel 1.8A
ATI AIW 8500DV
Thanks
Spac3d
