Objective
http://oi53.tinypic.com/mb0k6p.jpg
Problem
Video is fine but no Audio.
Setup
Motherboard: Intel BOXDG41MJ
CPU: Intel E5400
RAM: Mushkin 2x2GB PC2 6400
OS: Win 7 Ultimate 64
TV: LG 32lh40
Drivers All from Intel site
Chipset - 9.1.2.1008
Audio - 6196
Video - 15.17.10.2189
BIOS - 0007
Some stuff I tried/noticed
- Unplugging HDMI produces sound. Plugging it back in, makes the sound go away again.
- Plugged in my Macbook (Intel GMA 950 chipset) with exact same wires (DVI + Audio) and got Video and Audio to work.
- VGA + 3.5mm Audio works as well but can not get a good resolution
- Talked to LG people. They blame it on PC.
- Talked to Intel people. They blame it on TV.
Here's what I think is happening ... For some reason LG TV sees an AUDIO signal over HDMI and does not switch to RGB/DVI IN input. Meaning, G41 Chipset is sending something that makes LG believe there's AUDIO on the line.
There're some tutorials that advise overwriting EDID/CEA data to disable CEA portion (which carries Audio settings among other things). I've tried that and it didn't do much.
I find it interesting that the older Intel GMA 950 chipset is properly handling the data where the newer G41 chipset is screwing it up somehow. Although this is most likely the driver/OS/something software related.
I'm definitely running out of ideas and I googling didn't produce anything constructive. Any ideas/suggestions?
Problem
Setup
CPU: Intel E5400
TV: LG 32lh40
Audio - 6196
BIOS - 0007
