Originally posted by: Nebor
Are these TS or TP files? What were they ripped from? The only way to get HD onto a computer currently is by having an HDTV tuner card in your computer... And a lot of times you need an HDTV card to play back TS or TP files.
Actually, a certain motorola hd cable box can be hacked to allow it's firewire out to work w/ a pc....
Originally posted by: oog
you could try getting a program called gspot, which will tell you what codec you're missing. hopefully, it'll help you determine which audio codec you are missing.
