Question (*nix) using find, not getting the same results as with a search through UI (nemo)
mikeymikec
21,389
16,601
I had to do a manual install of makemkv (to get an older version of it), which resulted in a Mint launcher entry that lacked an icon. I wanted to find if/where the ico for makemkv was on my computer and modify the launcher entry.
I ran:
find /usr/ -name "makemkv*"
And got several results, but I get more results by doing a search in a file manager window (nemo, on Linux Mint). I suspect this is because the command I ran is asking for any files named makemkv*, but searching for makemkv*.* results in asking for files names makemkv with whatever then a full stop then whatever, which excludes files that were called for example 'makemkv'. If I wanted to get both sets of results with one find command, how would I go about doing it?
I've achieved what I want to achieve already (the launcher entry now has the proper MakeMKV icon) but I would like to learn more about stuff at the command line.
manly
13,501
4,190
Unclear to me why the results differed. Can you give a concrete example of what the UI found that the CLI didn't?
*.* is old DOS syntax, which I assume was inherited from CP/M? In other words, you wouldn't use the pattern 'makemkv*.*' unless you had a very specific reason to.
'makemkv*' would match just makemkv , or obviously filenames with additional trailing characters.
Here's a trivial example to illustrate that * matches 0 or more characters.
$ find /usr/bin -name 'find*'
/usr/bin/find
/usr/bin/findmnt
