Originally posted by: Roger
Chains do not need replacement on a scheduled basis, you only need to replace them if they are damaged, making noise or you are rebuilding the engine.
If you hear clacking noises, banging or whipping sounds coming from the timing chain cover, there is most likely some kind of damage to either the chain, guides, sprockets or tensioner.
would it be too late by the time you hear those noises? or is that kind of an early warning system that damage is imminent?
