I just bought a kit to replace my factory antenna. Unfortunately, after removing my old antenna the new antenna does not fit into the old antenna wire plug. The one on the kit is the normal antenna cable used to plug in your reciever but the one on the nissan is a much smaller hole.
I need an adapter but I cant find it. CAn someone help or give me some advice.
Thanks
Clocker
Thanks
Clocker
