Nine Hundred Case Purchased with Optional Fans
Aug 13, 2007
26
Which way do I install them? The antec logo facing the motherboard or me when its on the side panel? When its in the hard drive cage, does the antec logo face the hard drive or the motherboard? I got the Antec tri fans.
ChefJoe
2,506
Antec tri fans have the sticker on the "blow" side of the fan IIRC.
For the side panel usually people have those blow into the case.
PCTC2
3,892
33
I think it'd be pretty easy to tell the curvature of the fins. But as ChefJoe says, it is flowing from fan-hub to sticker side. So in the optional HD-Bay cage, the sticker is facing the motherboard.
However, on the side fan, it depends if you want intake or exhaust. I use it as an intake and get about ~7C cooler temperatures across my GFX cards. Others use it as exhaust and say they get better results. Try both ways and see.
