Hi, Rechargables are terrible in some devices that were designed for Alkaline batts. Rechargable batts start a about 1.3 volts per cell, drop very rapidly to 1.2, hang there through the entire live of the batt then drop rapidly all the way down. Alkalines start at 1.6 Volts per cell and drop gradually for their entire life. The device shuts off at about 1.2 Volts per cell which is where the Rechargables like to be so you don't get but a tiny bit of their life. If the device has no auto shut off then they work great. Some types of chargers only time the charge so will not fully charge larger capacity cells with one cycle. You would have to run them another cycle and shut it down when you know they are fully charged. Some really intelligent chargers should do a good job. The Dollar stores in my area have Everready, 2.4 Amp Hour MiMh batts with the correct charger for $10.00. Hope this helps a little, Jim
Edit: The general concensus seems to be that Rechargeables self discharge rapidly. True, but the above points out that it's not really the self discharge but the fact that most devices are not designed for rechargeables. Run a set down in a Camera and then test with a known drain and you will find that the batt still has most of it's charge available. One of my many cameras does not shut down but only indicates when the batt is down. It takes over 100 more flash shots at highest res after the batt is "Dead".
Jim
