Night Vision Cameras
Wheezer
my car has been getting vandalized and I think it might be the neighbor punk...I have filed reports, but nothing so far....I want a decent night camera so I can record, nightly activities outside...the range should be about 60 feet, it does not have to be wireless, but something that could record to my computer would be great...thanks
Anyone got a model or models the would suggest?
Anything decent will run you several hundred for a camera and video capture devicewith software. If you want to do it cheaper then go black and white, as the color infrared/night-vision cameras switch to B&W at night anyway. For best look for a camera with a Sony CCD. I used to work for a place that sold CCTV, good equipment but not always the lowest price. PM me if you need the website.
edit : and if you have no budget then extreme cctv has the best nightvision stuff
Originally posted by: nova2
i just looked at x10 and this fat javascript popup appeared that scrolls with you until you exit it.
that didn't impress me.
Strange, I dont get that and the site is easy to navigate😕
