nifty little heater - eden pure knockoff
Status
Not open for further replies.
slag
10,473
We picked up one of these a couple weeks ago at Menards and really like it. Heats our master bath great and helps in the master bedroom as well. Super quiet, programmable, and has a remote.
http://www.menards.com/main/p-1444442891539-c-5617.htm?tid=-528980869345780548
When we get around to changing the tile in the bathroom, I'm going to go with an electric radiant floor system so we won't need a heater in there, but in lieu of that, its a nice little heater that really puts out a lot of heat.
Portable infrared electric heater with 4 quartz elements is a safe and efficient way to supplement heat in your medium sized room. It features a Cool touch exterior cabinet, Tip-over and over-heat shutoff for safety and a programmable on /off timer for efficiency. It comes with a convenient remote control, digital display and three heat settings including our "ECO" mode which keeps the temperature a constant 68 degrees. Smooth glide wheels make it easy to move from room to room.
Heats up a medium room
  • Four infrared quartz elements
  • Three Heat Settings: High 1,500 watt Low 750 watt ECO-maintains a constant 68º
  • Digital control panel for temperature, time and power
  • Full function remote control
  • Cool to the Touch Black Plastic Cabinet
  • 1-year limited warranty
  • Lifetime washable air filter
  • ETL certification
  • Caster wheels allow for easy portability
  • Child Safety Lock, Overheat Safety, and tip-over safety shut-off
Status
