whatsyourdeal
Banned
Xact Sirius Satellite Radio Bundle
For the Sirius yahoo
$149.99 + $5 Shipping and Handling
Features:
Sleep timer
Auto power-off
Clock with alarm
Adjustable brightness and contrast controls
Wireless remote control
Plug and play palm-sized SIRIUS tuner
105 streams of Sirius satellite radio
18 Stream preset compatibility
Multi channel wireless FM connection
Wireless IR remote control
Dual stereo headphone jacks
Amber, backlit LCD screen
Readout displays channel info, category, preset bank and number, artist, song title, and the time (up to 6 lines of info)
S-Seek stores info for up to 10 songs and will alert you when a saved song is playing anywhere on Sirius
Search by category, channel, artist, or song title (displays all artists or song titles currently playing on every channel)
Parental control allows channels to be accessed only with a security code
Tuner dimensions: 2-3/4?W x 4-5/8?H x 1-3/8?D
XS021 Sirius Vehicle Kit
Includes:
Docking Module: The docking module features a proprietary multi-pin connector that plugs into the bottom of the Stream Jockey and a clip that locks the receiver to the module. The back of the docking module contains three jacks: a DC power input, an audio output (3.5mm mini-jack), and an SMB antenna jack for the supplied Sirius antenna.
Car Base: The Vehicle kit comes with an adjustable car base that can be attached to the vehicle by the supplied self-adhesive pad, or with 4 screws (not supplied). When secured by the self-adhesive pad, the car base can swivel 360° and be positioned in any of 20 stops. The Stream Jockey, when mounted to the base, can tilted forward or backward and locked into place. The car base attaches to the back of the receiver via 4 pins and a thumbscrew.
Antenna: The kit comes with a magnetic Sirius satellite antenna with a 21? cable. The antenna cable has a single SMB connector. The antenna can be installed with or without the supplied 6-1/2? rubber tail. A packet of cleanser with antistatic is supplied to prepare the spot on the vehicle where you choose to install the antenna. Dimensions: Width=1.889?, Height=0.651?, Depth=2.64?.
Cigarette Lighter Adapter: To supply power to the Stream Jockey receiver, the vehicle kit includes a cigarette lighter DC power adapter with an attached 6? cord.
Signal Output: There are two methods of inputting the signal into your car stereo system. If your stereo receiver has an auxiliary input, you can use the 3.5mm mini-jack output on the back of the docking module to feed satellite audio directly into the receiver. If the stereo has no aux input, you can use the Stream Jockey?s built-in FM wireless modulator and tune to the selected transmitting frequency on your stereo?s FM tuner to hear the satellite audio.
Features:
Vehicle docking cradle
Low Profile Magnetic Antenna System with 21 Ft. of Micro Coaxial Cable
12V vehicle power adapter
Wireless FM transmitter
Measures 9-1/2? x 12-1/2? x 5?.
Stereo Auxiliary Output Adapter (Stereo Mini to Dual RCA)
XS024 Sirius Satellite Radio Portable Boom Box for XTR1 Receiver
Get big sound with a low profile from the XACT XS024 portable boom box. Powered by either AC current or 6 "C" batteries (not included), this great sounding boombox lets you take your SIRIUS radio anywhere.
Features 3? full range speakers with 2.5 watts per channel ? Big Sound, Low Profile.
Compatible with XTR1 Stream Jockey Satellite Radio Receiver
Includes Satellite Antenna
3? Full Range Speakers 2.5w Per Channel
Rotary Volume Knob
3.5mm Stereo Mini Jack
Receiver Eject Button
Extended Outdoor Play with 6 C Batteries, * Batteries not included
http://www.woot.com
