Nice Deal?: FSP GROUP 300W PS, P4 478 CPU COOLER & 92mm case fan for $19.99
Seems pretty nice to me. I'm just putting together a HTPC and need a quiet PSU. Wonder if this 300w is enough.....was hoping for something a little bigger, but this price sure is nice!
it says 300 continuous so I bet it's 400+ peak watts. FSP is solid and this spec is more than enough for HTPC. But the description is confusing, first it says 120mm exhaust fan, then it says dual 92mm on the PS, then a 92mm for the case fan... I don't think you get a 120mm 😕
EDIT : nm you get two 92mm fans one for CPU and one for case.. the 120 is in the PSU
Good deal pretty hot thanks OP
Hmm..I think you're right - I misread it. I'll change the thread title....... 😱
That's a pretty hot deal as long as you don't need 24 pin ATX motherboard power (as in your board doesn't have PCI-E). 300W of quality power such as provided by this Fortron is enough for most moderate systems.
I saw this in the email, not bad really. Comes with a 80mm fan adapter also. According to their shipping calculator, ground would be $7.43, not great, but not horrible.
I found the 350W version of this kit on the FSP site
This might be the PSU, although it doesn't have the fan control on the back like the one in this kit does.
Also, a review
I don't think it's confusing, at all- 120mm psu fan, 92mm case fan w/ 80mm adapter, S478 heatsink with 70mm fan- each temp controlled...
Nice deal, considering that FSP isn't junque, at all...
