Nforce2 SN45G expiriencing sound problems
gogeeta13
5,721
I have an SN45G...running windows XP PRO.
loaded the nforce drivers off the cd that came with it.
in counter strike, after about 10 minutes, all sound on the system becomes fuzzy, distorted and slightly slow.
it doesnt happen unless I play CS, and not until like 10 minutes.
jhbball
2,917
23
the "fuzziness" is usually attributed to heat. try stick an extra cooler on the southbridge.
nanaki333
3,772
13
or you can try just taking off the side panels to your case. that should cool things off quite nicely. :)
