Nforce 680I SLI mb, yellow led?
CHARLIEBORG
510
My sons computer died this past week. I replaced a bad power supply, but now when I try to boot it up I see a yellow LED just to the left of the blue one? Has CR12J2 stamped next too LED. No numbers on the post board display though? Tried unhooking all the drives, usb, and other stuff, plus took the ram out. Still got it? Any one know what the LED is for?
I have a picture of the led and its location it that will help. Just cant attach it to message.
hennessy1
1,901
Have you tried removing the cmos battery for a bit? I believe that code and light has to do with a power supply as well.
Iron Woode
31,170
12,701
sometimes when a PSU craps out it takes the MB with it.
I hope that isn't the problem but you must keep that in mind.
PS: you need to save the image to an image hosting site and then post it here using the img tags.
dawp
11,347
2,709
it would also help to list exactly what board you have. a number of vendors made 680 boards and not all had leds on them.
Iron Woode
31,170
12,701
according to the manual, you have an LCD post code display. What does it display when you boot up?
john3850
1,436
21
net search cr12j2 led many evga hits
Go to egva forms search under 680i
cr12j2 and or any leds are not listed in there 680 manual ,
fjbredtjr
i have a very similar issue on the same board. :[
wondering if you ever figured anything out?
