nforce 4 ultra drivers and lan
engagequadlaser
15
I've recently put together a system with the following mobo:
ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813131530
After a rather difficult time getting my isp to switch over the mac address so that the internet works on the new computer and getting windows installed and upgrading to service pack 2, I set a restore point and install the latest nforce 4 amd drivers from nvidia's site. After the reboot, suddenly my internet is no longer working. I figure maybe another mac address issue, but calling up my isp has them telling me they show me as connected. Sure enough, if I open the command prompt and ping various sites, I get a normal response. When I open outlook and try connecting to the isp's pop mail server, it correctly prompts me for a login and password. Hrm. Opening internet explorer just has it tell me it cannot open the site. Also if I try to change the address in the bar and hit enter, it tells me it "cannot find the search page".
On my current motherboard (msi k8n neo 2 platinum) I recall trying to update my nforce 2 drivers and running into a similar problem, suddenly I wasn't able to connect, and only a system restore fixed it. Interestingly, in this latest case a system restore was not able to fix the problem. I guess I'm just wondering if anyone has any idea what's going on, has had this happen to them before, or has any suggestions on what to do. Was debating if maybe it's just a problem with the onboard lan, and if buying an ethernet card would help resolve the issue finally. Thanks in advance for taking the time to help!
engagequadlaser
15
I'm almost 99% certain that during the initial install of the nvidia chipset drivers, when asked if I wanted to install the nvidia firewall I clicked 'no', so I'm fairly confident it shouldn't be there. At any rate, I tried doing a add/remove programs / nvidia drivers and removed the ethernet drivers component. Did a reinstall of the nforce drivers, and this time clicked no to the firewall, but that still didn't result in a fix. Could be I needed to call the isp and have them update the mac address again, but who knows.
allanon1965
3,427
was your ethernet plugged in while you were installing the nforce drivers? if so unplug it and re-install. this happened to me and I came to the conclusion that the drivers dont install correctly when the cable is plugged in, but when its not, they install great...and i can make it happen consistently...so i know it works in my case...
