NFII Startup problems
RossAdamBaker
25
Hello everybody,
I am experiencing two issues with my system starting up, if any of you have heard of these problems or know of anything I can do to fix them, I would be very greatful! Thanks!
1) Every once in a while, when I power on the system, all the fans and whatnot come roaring to life... but no video. After about a second, the system speaker starts beeping, about twice a second, in two pitches... high, low, high, low, high, low... and on and on and on. If I reboot the system, usually it works fine.
2) Every once in a while, the system goes through POST, I type in my password, and it then checks the SATA drives attached... finds my western digital raptor wd740gd, then just sits there with the little blinking cursor thing. It'll sit there forever, until I restart the system, at which time it usually loads correctly again.
Thanks in advance for all of your help!
