thewizard1785
Banned
NF7-s v2.0
AMD 2600+ mobile & slk 900u
Corsair Ram
fortron PSU
9700 pro
Seagate 40GB
So I get all my hardware into my case hooked up properly and I turn on the system. I realize that I forgot to hook up a floppy and so I turn off the system and add the floppy drive. I tried to boot the system again and the mobo would start beeping like an ambulance. I remove the floppy drive and try again and the same problem. So I make a checklist to make sure each and every single wire is attached properly. I do that and try again but no success. It sounds exactly like an ambulance.
What do you suggest I should do?
Corsair Ram
fortron PSU
9700 pro
Seagate 40GB
