- May 3, 2004
- 140
- 0
- 0
Hey Guys, new to the forums.
I have purchased an NF7-S, 2500+ mobile Barton, DDRAM 256M|DDR400 CL25 PC3200 -k RT Kingston mem, SLK-947-U HSINK ONLY THR RT , and Vantec Tornado fan.
But I am only able to OC to 2.21ghz. And even that is not 100% stable. Plus I am running kinda hot. Just leaving my comp on for a few hours doing nothing Sandra and bios are reporting 50.5C.
I read some threads and someone mentioned to make sure all the fans were blowing out. So I have the Vantec fan and top case fan and the other case fan on the side blowing out. Nogo.
Then I read to open the case and see if the temp goes down. I opened the case, nogo. So I took off the massive heatsink and reapplied the thermalpaste and reclamped the heatsink making sure to go opposite corners while tightening. HS is on tight, not moving at all.
Same thing. Still a high temp just idling and not all that stable playing Sacred. Yes, I am well aware of Sacred having serious gaming issues.
I have played around with the voltage a little. Right now I have it set to 1.7225 and Sandra is showing it at 1.67v. If I decrease it the comp has a nasty habit of rebooting during a game.
Also, I have the OC set to 200mhz FSB and 11.0 mutiplier. Is this just a case where I should just be happy with what I got or is there something else ya'll could suggest?
