NF4 Lan or Marvel Lan
jose
Hi everyone,
Which port are you using w/ your NF4 mobo ?
Is the marvel lan better, less problems or they're both the same ?
Regards,
Jose
i think the marvell uses less CPU resources, but I dont think it transfers quiet as much. I figured it wasnt likely to be noticeable so I just used the Marvell
