Are you only looking at android? The iphone 6 is 4.7" and available in 64GB and even 128GB.
Whatever you may think of iOS, at least Apple doesn't gimp the crap out of any phone under 5"
Too bad because if I could get an iphone5-6 form factor android with better battery and good specs id be all over it.
If you need CM so badly then get a phone which runs CM natively. If you get something which runs on its own Android skin (Sony, Samsung, HTC etc.) then don't expect them to give you all the bells & whistles of CM (to whatever extent those exist) Cyanogen anyway, you'll always lose some features, unless you don't use a phone really seriously.
ok so after researching, pretty sure im gonna pick up a oneplusone, since its by far the best deal. My only concerns are:
1. Im used to lollipop, and dont wanna go back. What is the status of lollipop on this device? I saw CM released a nightly, but is that how updates are on this phone?
2. Cyanogen skin. I really like just plain old boring stock android. Is there a way I can flash this? Or make cyanogenmod look/work like this?
3. quality control. Ive heard some bad stories, but not enough that are gonna keep me away from buying. But it is a small worry.
Ideally I would want a nexus that runs stock android. CM is the next best thing for me - which is why I went with the OPO.
Cant I make CM look like just plain stock android? Ive seen some videos of the OPO and not sure if i like the theme. And how stable are nightlies of lollipop on the opo? Not sure how I feel about going back to 4.4 after using 5.0.
