Lazarus52980
I am working on a PC for someone where they are having odd errors in Windows. I started with a SFC /scannow and it came up with errors it was not able to fix. I tried using a windows 7 disc, running a repair and doing a system restore, but it fails on the system restore.
Do I have any options other than a clean install of windows? I would like to avoid that if at all possible...
Thank you for any advice you might be able to share.
