- Mar 11, 2004
- 23,441
- 5,841
- 146
http://autos.yahoo.com/news/next-corvette-will-be-powered-by-small--high-revving-turbo-v-8.html
Yes, please.
And before people freak out:
Hmm, the mid-engine rumors persist:
Personally, I wouldn't have a problem with them doing some pretty drastic stuff with the Vette. They've already tried sorta a tier with the C6, maybe they're going to take that even further? Its working out very well for the Mustang, and the Camaro is set to follow suit (and is selling well too), so the Vette could move upmarket well. Performance and value are two of the main draws, but the ZR1 has proven they can go crazy with it too. I know plenty of people think it should be front-engined only, and maybe they can do front-mid or something with a compact engine.
GM has approved the use of a very European-style V-8 that will be only slightly larger than 3 liters in displacement. The engine will be an overhead-cam, rather than traditional overhead-valve design, using a dry sump oil system thats particularly well suited to high-performance road courses rather than straight-line acceleration. The engine is expected to feature a narrow 80.5 mm bore and a long stroke, more like a Ferrari or Lamborghini powertrain than the approach used for traditional Motor City metal.
A very senior GM executive also confirmed that the new engine will be turbocharged, which will help yield a broad torque curve and maximum performance under a variety of driving conditions. The engine is expected to deliver in excess of 400 horsepower, which means a specific output in the range of 125 horsepower per liter. Thats the sort of number that would help the next-generation Vette stack up well against the likes of a Porsche 911 or Lamborghini Gallardo.
The engine is likely to be extremely high-revving, perhaps climbing to a near-Formula One-class 10,000 RPMs, suggested one source involved in the project.
Yes, please.
Significantly, Corvette wont abandon its more classic powertrain roots entirely. There will be several different types of engines offered for the C7, including a more classic, big-block OHV V-8 designed to appeal to traditionalists.
Adopting a mid-engine layout, rather than the long-running front-engine design, is considered a strong possibility, though it would be a significant engineering shift for GM. Nonetheless, sources say that wouldnt be entirely out of line, as the Corvette has often served as the technological test bed for the maker.
