Newer Pontiac Sunfire not compatible with most car stereos?
wetcat007
3,502
I'm looking to get a Pontiac Sunfore, i was looking at a 2001 model, and I was planning on instaling my owns tereo, hwoever upon using bestbuy's fit guide, i discovered that on 2000 and newer car models almost none of their stereo decks will fit? Is that right? What's with that? Can anyone clear this up for me i'm not sure why they'd change a car to make it incompatible with other stereo systems.
-Mark
atom
4,722
Buy a DIN adapter, it's probably because of the special GM DIN size.
boomdart
825
You just need to buy a ...erm... cd player kit thing, it'll fit right in there. $15 at autozone, don't forget the wiring harness for ~$5!
hmph...the wierd thing is when I started to reply no one else had replied yet >_< :p
aircooled
15,965
Your car is a Caviler (or J-Body GM). There are adapters made especially for the J-body radios.
BillGates
7,388
Check Crutchfield - if you buy a stereo from them they'll give you the mounting kit and wiring harness in most cases. (The head unit will be more expensive but you get good support)
LordMorpheus
6,871
heh. I was getting a new deck for my Sable, and when I took it in the car stereo guy almost crapped himself, until he learned my car was really old and before they started putting those fugly oval and curvy stuff inside. I bet that it would be damn near impossible to decently install a stereo in a mid-90's taurus or sable.
rudeguy
47,351
14
61
he hee...you have the football radio
nothing too bad to do a deck on that. Just a $100 install kit, $150 worth of labor, and about 2 hours of an installer's time
wetcat007
3,502
Thanks for all the help, how hard is it to install one of these yourself? Bestbuy has free installation on it, but they dont carry the adaptor as far as i know.
T2T III
The installation is pretty painless. Don't forget some wire nuts to connect the wires between your new head unit and the plug/adapter for the wiring harness. Other than that, just follow the instructions and you should be OK. The only thing that might get in the way is if the Sunfire has a rear radio bracket holding the system in place. If so, you might have to fit your hand into a very thight area to get the nut/bolt loose.
You could still check with BB and see if they can special order the adapter for you. As long as the installation is free, you might as well take it. Just check all of the connections when they are done - to make sure none of the wires are loose, etc.
Ryan
27,519
Why are you looking at this shitpile of a car to begin with? Don't you know that Sunfires and Cavaliers are some of the WORST vehicles EVER MADE?!?!!
wetcat007
3,502
Well what's a better car I can get, I need something with under 70k miles and under 7000 dollars, and not a real old vehicle preferably a coupe.
AvesPKS
4,729
A hundred dollar install kit? I think I paid like $15 for the adapter, and I was able to carry over the wiring harness from my old car. Plus my cousin and I installed it in like 15 minutes.
CraigRT
31,440
almost anything but what you are looking at man.
suggest one other car in that price bracket and most people will say its better.
i would be one of them probably :)
wetcat007
3,502
lol the thing is there arnt many cars in that price bracket/miles range... any ideas would be helpful though!
StageLeft
70,150
Congrats on focusing on the worse car on the planet :)
They are THE worse cars ever made :D
Ryan
27,519
I can't think of much right off of the top of my head, but here's a few:
2000+ Ford Focus 2-door
Honda Civic Coupe (probably the best econo-coupe available)
Oldsmobile Alero Coupe (still worlds ahead of the sunfire, and it looks good)
A 98-ish Toyota Celica
A 98 Nissan 200sx SE-R
98 Nissan 240sx
97 Honda Prelude
Ryan
27,519
No, any Daewoo is worse.
amdskip
22,530
13
IIRC, you need to keep the factory radio installed as it is a computer of the car controlling a bunch of stuff. It has to be reinstalled in the trunk.
rudeguy
47,351
14
61
oh read your post wrong. You said your car was before the footbal radio. You shouldnt have even needed a kit for an older Sable.
