Newegg.com - GIGABYTE B560M AORUS PRO LGA 1200 Micro ATX Intel Motherboard $119.99
VirtualLarry
GIGABYTE B560M AORUS PRO LGA 1200 Micro ATX Intel Motherboard $99.99
  • Intel B560
  • Supports 11th and 10th Gen Intel Core Series Processors
  • Dual Channel Non-ECC Unbuffered DDR4, 4 DIMMs
  • Direct 12+1 Phases Digital VRM Solution with 50A DrMOS
  • Shielded Memory Routing for Better Memory Overclocking
  • Fully Covered Thermal Design with High Coverage MOSFET Heatsinks
  • Blazing Fast Intel 2.5GbE LAN with cFosSpeed
  • Dual Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with Thermal Guard
  • SuperSpeed USB 3.2 Gen2x2 TYPE-C delivers up to 20Gb/s Transfer Speeds
  • Pre-installed IO Shield for Easy and Quick Installation
  • RGB FUSION 2.0 with Multi-Zone Addressable LED Light Show Design
  • Smart Fan 6 Features Multiple Temperature Sensors, Hybrid Fan Headers with FAN STOP
  • Q-Flash Plus Update BIOS without Installing the CPU, Memory and Graphics Card
If this is any indication, then Newegg may be starting to fire-sale their 10th/11th-gen mobos. There's an MSI B560 mATX for $89.99 as well.
Edit: Now up to $119.99.
