Newby mobo hook up connection
hayu82
Hey guys, working on my first build. Just have a question.
I was wondering how to connect the front panel wires to the MOBO? I'm looking at the "panel1" pluggers and on the diagram one pin is labeled N (for neutral?), so then is how do I tell which hole is for the neutral one on the wires from the panel itself? I did notice that there's a small triangle labelling one of the holes, is that for the N one?
Thanks!
