Newbie question about Panaflow fans and connectors
fwtong
695
I just got some Panaflo fans and some connectors. I'm pretty sure I just stick the bare leads into the connectors, but I just wanted to make sure that's all I need to do. I don't want to screw up, just in case something bad happens if I do screw up!
fwtong
695
Cool, thanks. What's the best way to secure the bare leads to the connectors, so they won't slip out?
sugarkang
248
they won't slip out unless you've got the side panel open and you have a dog or a small child that likes to pull wires.
Ness
5,407
If you are that worried about them falling out, either wrap a small piece of electrical tape around the back of the plug or warm up the glue gun and put a small spot of glue back there... or a combination of the two. But as long as it has the barbs in there, it should be fine.
