Hi there,
I am in the process of putting together my new computer. I purchased the chieftec case off of Newegg a while ago and it did not come with a psu. I bought an Antec Tru Power 330 and I have it in the case now. I dont wanna screw things up so is the way I have it installed the correct way? It looks up side down. The only way the screw holes would match the case is if the fan on the psu (inside the case) is on the bottom. Is this the right way? The power cord will be coming
out the bottom left...the switch on the top left..The external fan on the right.. Any help is appreciated
Thanks
Thanks
