Hi folks!
I currently have a setup like this:
EXAMPLE PIC
Essentially; 2 Cablemodems, each going through a router, which then connect to the 2 NIC ports in my PC.
My problem is; I keep enabling one and then disabling the other, inside of the NETWORK CONNECTIONS list in Windows XP, which is how I switch between them. But the problem with that is, when I hop onto CABLEMODEM 2 to do downloading, my XBMC and other computers on NETWORK 1 can no longer interact with the PC because I had to disable that ethernet port in Windows.
My question is, how can these both co-exist with eachother? When I do downloading on NETWORK 2 I hate how my XBMC which is on NETWORK 1 can no longer stream files from my PC because I had to disable NETWORK 1 in the Network Connections list.
Is there some kind of utility I can use for Windows, which will let me bind programs to a certain interface? IE: I load up uTorrent and bind it to my NETWORK 2 connection, but other computers from NETWORK 1 can still interact with the PC.
Sorry, its hard to explain, but hopefully someone can understand what I'm saying and figure out some kind of solution for me
It really is getting difficult and annoying to have to either pic ONLY one network or the other, I just want them both to work
Thanks, and please let me know if you have ANY suggestions!!!
Cheers
EXAMPLE PIC
Cheers
