Here is all my system info can anyone recommend anything as far as settings to try? I'm having a hard time finding a multipier in bios. Thanks for any help
--------[ Overclock ]---------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type AMD Athlon 64 3200+
CPU Alias ClawHammer S754
CPU Stepping SH7-C0
CPUID CPU Name AMD Athlon(tm) 64 Processor 3200+
CPUID Revision 00000F48h
CPU Speed:
CPU Clock 1999.11 MHz
CPU Multiplier 10.0x
CPU FSB 199.91 MHz (original: 200 MHz)
Memory Bus 199.91 MHz
CPU Cache:
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 1 MB (On-Die, ECC, Full-Speed)
Motherboard Properties:
Motherboard ID 62-0512-009999-00101111-040201-VIA_K8$1XXXX000_A6741VMS V1.3 051204
Motherboard Name MSI K8TM-ILSR (MS-6741) (3 PCI, 1 AGP, 1 CNR, 2 DDR DIMM, Audio, LAN, IEEE-1394)
Chipset Properties:
Motherboard Chipset VIA VT8383 Apollo K8T800, AMD Hammer
Memory Timings 3-4-4-8 (CL-RCD-RP-RAS)
Command Rate (CR) 1T
SPD Memory Modules:
DIMM1 1 GB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM2: Samsung M3 68L6423ETM-CCC 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS Properties:
System BIOS Date 05/12/04
Video BIOS Date 03/07/23
DMI BIOS Version Version 07.00T
Graphics Processor Properties:
DirectX 4.09.00.0904 (DirectX 9.0c)
Video Adapter ATI Radeon 9600 (RV350)
GPU Code Name RV350 (AGP 8x 1002 / 4150, Rev 00)
GPU Clock 324 MHz (original: 324 MHz)
Memory Clock 202 MHz (original: 203 MHz)
Sensor Properties:
Tsystem 46 °C (115 °F)
Tcpu 43 °C (109 °F)
Fcpu 3245 RPM
Vcore 1.49 V
Vio 3.31 V
CPU Properties:
CPU Stepping SH7-C0
CPU Speed:
CPU Cache:
Chipset Properties:
SPD Memory Modules:
BIOS Properties:
Sensor Properties:
Tcpu 43 °C (109 °F)
Fcpu 3245 RPM
Vcore 1.49 V
Vio 3.31 V
